Performance and Tuning Discussion forum for various performance tuning techniques and questions
a Klunking sound from right rear H&R / Bilstein sports on A4...
Old 10-30-2000, 06:50 AM
ReyHey's Avatar
Default a Klunking sound from right rear H&R / Bilstein sports on A4...
it has gotten progressively worse over the weekend.
it sounds as if it is rebounding off the body.
I have not raised the car up (as I live on hills)
to check the mounting bolts, a couple of waterfront mechanics I mentioned it to think Bushing?
the car will be getting a Tech inspection within a couple of days, just thought I'd ask here while I'm at it.
any input from you Audi pros??
Thanks
Rich N.
Old 10-30-2000, 08:11 AM
WJM
WJM's Avatar
Default do you have a 99.5 A4?
if so it may be your control arm...
mine is getting replaced in that corner
Old 10-30-2000, 08:28 AM
ReyHey's Avatar
Default MY00' QMS...
any ill effects progress over time?
I have the 2 final rounds in an Auto-X this weekend I'm leading in, also entered in Quattro driving school at Sears Point in a couple of weeks!
Thanks
Rich N.
Old 10-30-2000, 08:47 AM
Junior Member
Adam S's Avatar
Default Could also be a loose bolt.
I would check all the suspension components to make sure nothing was loose. Who did your spring/shock install? You might want to have them take look.
Old 10-30-2000, 08:49 AM
WJM
WJM's Avatar
Default it is a bushing...but they replace the arm...
WORST CASE: I'd just check the bolt after/during these events. Do a torque check on it to make sure it hasnt broken on you.
talk to dealer as the parts I believe are on backorder
-Will
Old 10-30-2000, 09:10 AM
ReyHey's Avatar
Default thats my plan Adam! I just need to look in there...
But, thought I'd just ask here first.
Old 10-30-2000, 09:13 AM
ReyHey's Avatar
Default thanks WJM, I did just speak to the dealer.....
His "phone diagnosis" are not very good (Service manger)? I just need to lift the car, but I figured to ask here first.
Good input, thanks
Rich N.
adminisTerTurbo
Audi Original "S" Cars
15
05-28-2008 10:27 AM
RVL
08-10-2006 08:44 AM
.357
08-12-2004 05:52 AM
ReyHey
10-30-2000 09:19 AM
Quick Reply: a Klunking sound from right rear H&R / Bilstein sports on A4...
