Performance and Tuning Discussion forum for various performance tuning techniques and questions
Knocking sound from right rear corner when I go over speedbumps,railway crossing and depressions in
Old 12-22-2000, 02:02 AM
New Member
Goldeneye's Avatar
Default Knocking sound from right rear corner when I go over speedbumps,railway crossing and depressions in
the road.I have Koni coilovers and cannot seem to figure out the clicking/knocking noise!I am also running 18" with 225/40 p7000 ss.Please help!!
Old 12-22-2000, 06:48 AM
Leszek's Avatar
On my car it was the sway bar coming loose and detaching itself.
Old 12-22-2000, 11:49 AM
Member
dingster's Avatar
Default I have H&R C/Os and I get the same sound from right rear
I took the suspension apart and put it back together and torqued everything to spec and it's still making the same noise. I'll check the sway bar to see if it's loose.
Old 12-22-2000, 02:48 PM
New Member
D.C. Lee's Avatar
Default Re: I have H&R C/Os and I get the same sound from right rear
Check the shock body to make sure the springs aren't rubbing against the strut shaft. This is what caused my groaning problem. H&R just fixed it with new rear struts that (unlike my original set) use the stock top shock mounts, plus new tapered mainsprings designed to avoid the rubbing. Worked like a charm. If it's not the coilovers, the rear swaybar would be a possible suspect, especially if it is after-market.
Lee in D.C.
Old 12-22-2000, 07:55 PM
Member
dingster's Avatar
Default I have the G2 H&R C/Os. It's impossible for the springs to rub against the shock shaft.
I doubled checked that. I suspect it's either the swaybar or something is internaly wrong with that shock.
Old 12-24-2000, 01:50 AM
New Member
Goldeneye's Avatar
Default I orignally had the H&R c/o kit and was still getting the noise so I switched to the Koni's and it
is still there.I will check out the swaybar bolts and basically re-torque everything.Thanks.
Old 12-24-2000, 03:35 AM
Banned
Er-excess-4's Avatar
Me too; I've got Bilstien/Neuspeed Sport set up-HMMM
Old 12-24-2000, 06:29 AM
Member
dingster's Avatar
Default How does the Koni kit compare to the H&R?
Ride, Performance, etc...
TIA
Old 12-28-2000, 04:53 PM
Junior Member
zain's Avatar
Default Same with my H & R - right side, sometimes left.
Been doing it since they went in, got used to it after a while.
siki
09-05-2006 03:12 PM
WECoyote-SuperGenius
11
12-12-2005 09:17 AM
4heid
02-07-2005 06:54 PM
elgatoborrador
01-31-2005 09:27 PM
vonSol::kinkS4
13
02-24-2004 02:05 PM
Quick Reply: Knocking sound from right rear corner when I go over speedbumps,railway crossing and depressions in
