KO4 Questions?(more inside)
Thanks to all the responses concerning ATP's GT25 kit, I have decided to go with the KO4 for my 99.5 TIP. Now that I have decided that, what about tuners for the KO4. Im looking for the most performance possible from the KO4. So in saying that; How does the AWE kit compare to the Neuspeed kit and the Evo Motorsport kit? Any experiances with any of the mentioned would be great. Is it worth adding a FMIC and ported and polished exhaust manifold to the kits? Also EVo has stages to their KO4 kits. How does using a FPR compare to changing Injectors? Will their be a noticable difference between chipped and KO4'd?
TIA
99.5 1.8t TIP
GIAC
K&N
Borla
Baileys
TIA
99.5 1.8t TIP
GIAC
K&N
Borla
Baileys
Neuspeed K04 will have less power
The EVO, AWE, Matrix and DSR kits all use the same GIAC chips.
Yes it is worth it to even add a FMIC to a K03 so the K04 will take big advantage of that.
Not sure if GIAC does a kit for larger injectors, but going with larger ones will give you a more even amount of fuel thru the rpms and power. The stock ones just seem to lean out up top when ran with a 5 bar fpr.
Yes you will notice a difference between chipped and the K04. The k04 will kick in a little bit later but will have more power to redline. Manual cars tend to drop 1 full second in the 1/4 mile going from chip to K04.
Hohenester makes a kickass 258 hp kit with k04.
Larger injectors 350 cc, 3 bar fpr, larger maf, S3/TT 225 exhaust manifold, aluminium piping to the turbo and a new downpipe.
Or why not the APR 280-326 hp kit? Awsome!!<ul><li><a href="http://www.rattracing.com">http://www.rattracing.com</a</li></ul>
Hey Audi2ptzero......(inside)
Do you personally think a KO4 is worth it on a TIP? Can I make a decently quick kit(from a roll obviously)? Will a ported and polished exhaust manifold push boost farther up in the RPM range and if not how can it?
TIA
99.5t TIP
GIAC
K&N
Borla
Baileys
TIA
99.5t TIP
GIAC
K&N
Borla
Baileys
Check out O.CT too!
I am really happy with the O.CT K-04 Stage 2+ conversion on my A6!
Bob and Pete at Stratmosphere were very helpful in getting me set up.
O.CT has kits for 1.8
FYI, O.CT has a growing range of offerings for the 1.8T engine as well as for the 2.7T.
I think their stage 3 setup is rated at about 240 HP and the torque curve is FLAT. If it is anything like the setup I have in my car, it will be SMOOTH running as well.
Here is a link to A4/1.8 info on the Stratmosphere web site. I strongly suggest calling Bob or Pete, as many configurations and options exist. (also, Stage 4 is coming soon!)<ul><li><a href="http://www.stratmosphere.com/a4_engine_and_chips.htm">http://www.stratmosphere.com/a4_engine_and_chips.htm</a</li></ul>
