Logged some vag-com runs...do these look normal?
<center><img src="http://pictureposter.audiworld.com/143/vagplots-1.jpg"></center><p>Conditions:
Car warmed up, 61F ambient. Wett 1bar chip, 710N installed "reverse". New DENSO K20PBR-S10 "stock" plugs. 93octane, some techron still in tank.
On the 3rd gear WOT run, does the timing look right? It drops steadily...
On the full run, i think is slow shifted at the end of 3rd, perhaps that is why there is a blip there...but does the actual vs requested look ok?
TIA
TIA
not 100% about it.....
but I'd say boost looks ok...but the MAF should be over 150 for chipped...I think your MAF might be on it's way. Let's see what Audi2ptzero and others that know better say.
ok...yeah i have a 1bar chip, so a 2000mbar reading is perfect.
i did some searching...and i think you are right about the low MAF readings. I'll repost for the day crew tomorrow.
looks low
1 bar is probably enough to make a good 150 by 6000 RPM's. If you extrapolate that MAF graph out just a bit it looks like it would be at 140 or so at 6000 which to me seems lower than it aught to be. I think a stock car will show that much.
Re: baselines..
I need to get out there and just do it.....but I keep putting it off. Anyways, I have a stock ECU and a chipped ECU....plan on logging a few parameters. Will let you know how it looks.
Andy
Andy
Cool...I look forward to seeing them...I just ran 3 more 3rd gear WOTs..
<center><img src="http://pictureposter.audiworld.com/143/vagplot-2.jpg"></center><p>Pretty repeatable. And apparently low.
wagongotya
Rocky Mountain Discussion
23
05-05-2006 06:10 PM
TwentyValveB5+S4
02-10-2006 08:50 AM
Distinct
03-31-2005 01:34 PM
