Looking to upgrade to a remote oil filter setup (CM/Canton) would I benefit from a larger filter??
Canton offers both a 4" and a 6" remote oil filter.
Would I benefit from the larger 6" setup, or would it be bad.. I am thinking maybe a loss in pressure? Anyone have experience with them?
Thanks!
Thanks!
CM is a good setup for both oil and fuel. The only benefit for larger capacity is more miles...
between filter element changes. Larger doesn't filter better or more but it does last longer. Ideally it would be a good idea as the difference in costs between the two elements on the oil side only amount to a 22.23% increase over the smaller system while allowing a 75% increase in service life. And if you keep your remote location and plumbing as short as possible you'll be fine as Audi across the board provides a lot of short-run creativity for a remote mounting point.
Standard 2.625" elements cost $11.25ea while the larger filter is $13.75, only $2.50 (22.23%) more. Yet the larger filter has a 75% increase in filter media surface area which transfers to 75% increased life. If you do 10k mile element changes with the smaller element you could extend that to 17.5k miles with the larger element.
Dont dismiss their fuel filters summarily either. Their 1 micron element is probably the best filtration for our fuel injection that money can buy, bar none, PERIOD!
pocketchange
02-05-2012 12:26 PM
pocketchange
02-05-2012 07:47 AM
S4_Cinci (I S'edTFA)
02-21-2006 05:32 PM
