Performance and Tuning Discussion forum for various performance tuning techniques and questions
Lowering fuel pressure.
Old 09-18-2001, 09:54 AM
Rob K's Avatar
Default Lowering fuel pressure.
Are their any 3 bar fuel pressure regulators available as a drop in replacement for the 4bar regulators on the 12v V6? Lower fuel pressure will make it easier for me to achieve a good idle with 550cc injectors.
Old 09-18-2001, 11:13 AM
WYSIWYG's Avatar
i have one 3bar i use for the 1.8t, dunno if its different for 12v
Old 09-18-2001, 11:17 AM
scott12v@pghaudi's Avatar
Default Rob... I won't pretend that I understand the difference between 3 bar and 4 bar, but...
if I am thinking correctly, BAR is just another measeure of pressure. If this is the case, check out the link below. Justin and I are both running this FPR in our cars and it allows for adjustments between 30 - 100 psi. It's expensive at $195, but it drops right in and adjusting the pressure couldn't be easier.
Also, I received mine 2 days after ordering.<ul><li><a href="http://www.euro-car-service.com/a42.8infopage%201.htm">Adjustable FPR for 12V A4</a></li></ul>
Old 09-18-2001, 11:52 AM
xr4tic's Avatar
The V6s probably don't have a pressure/vacuum line going to it.
Old 09-18-2001, 12:03 PM
xr4tic's Avatar
Default yep, 3 bar = 44psi of base fuel pressure, 4 bar = 59psi of base fuel pressure, Looking at the pic...
it looks like there is a pressure signal on the FPR. Does the adjustment just change the ratio of air pressure to fuel pressure, or does it actually change the base fuel pressure?
Old 09-18-2001, 12:08 PM
Default I am 99.9% sure that the adjustment changes the base fuel pressure...
but I wouldn't want to be the source of misinformation so I'll say to give the place a call rather than relying on what I have to say.
Scott
Old 09-18-2001, 01:11 PM
Rob K's Avatar
Default Re: The V6s probably don't have a pressure/vacuum line going to it.
The V6 does have a manifold referenced FPR like the majority fuel injected cars, that allows for a constant pressure differential between the fuel and the intake manifold.
Old 09-18-2001, 01:15 PM
Rob K's Avatar
Default Re: Rob... I won't pretend that I understand the difference between 3 bar and 4 bar, but...
Scott,
Thank you that will work perfectly for what I need.
Rob
Old 09-18-2001, 02:09 PM
xr4tic's Avatar
I just noticed that it had one in the pic on the webpage that Scott posted.
Old 09-18-2001, 04:16 PM
Mike O.'s Avatar
NB 1.8T uses the 3bar. That's what I use with my 270cc injectors.
Quick Reply: Lowering fuel pressure.
