Modified S4 rear upper control arm
<center><img src="http://pictureposter.audiworld.com/1510/mvc-185s.jpg"></center><p>With this modification, we can easily adjust the rear camber by turning the threaded middle nut. It is much more precise than the eccentric on the lower control arm...also gives greater range of adjustment. This part is the same on the A4s
I believe DSR will have both front and rear adjustable upper arms soon
Made by Custom Performance. Very high quality stuff. The front ones uses National or Auroura rod ends and will also have rubber boots for longer life.
LuvnhatemyA6
04-29-2007 12:16 PM
