Need advice on upgrading to APR S3 with 106K on motor
I have an opportunity to buy my friends kit along with the APR clutch/aluminum flywheel. My car (AEB motor) has abou 106K on it and still runs strong. Has anyone here done a similar upgrade on a high mileage car? What should I lookout for? Would the flywheel need to be resurfaced? Of course I will have a compression test done first to make sure everything is good. Also, would I need to purchase new gaskets? Would these have to come from APR or are they the OEM ones. Any help/advice is greatly appreciated.
Thanks,
Mike5
Thanks,
Mike5
I'd buy new gaskets and fasteners. I'm not a believer in reusing those parts. Bear in mind, putting
a stage III kit on any 1.8t will magnify any Audi issues the car already has. I'd make certain everything was 100% before installing a turbo kit on any car .. let alone one w/ 106k miles.
That said, if the engine is healthy you should be fine.
If the compression test comes out OK...
you should be fine.
I would resurface the flywheel, and get a new clutch/pressure plate. I had a used APR flywheel and clutch which I put in, and regretted it. It didn't last very long before the clutch was toast.
Definately get new gaskets. I would think APR uses OEM gaskets, it may be cheaper to get them from APR as opposed to the stealership, and they're more likely to be the correct ones.
T-28-Quattro de VT
10-23-2001 07:23 AM
wasbri
09-09-2001 10:14 AM
apr310
09-06-2001 06:42 PM
apr310
09-06-2001 06:26 AM
Shoe
03-01-2001 10:31 PM
