Need clutch help, x-post
More details needed, maybe you can ask them...
When stepping on it for the 1st time, press halfway, does it disengage the clutch (shifting possible) ?
Then when you continue all the way down, the clutch engages (shifting impossible)?
Then as you go back up, keeping it halfway 1st, is the clutch still engaged? (shifting impossible)
or regardless of what's been done to the pedal, as long as the pedal is in the middle, shifting is possible?
What happened when your clutch broke, was it a broken clutch disk or pressure plate?
I'm betting if you past the halfway point, the fluid bleeds out of the master cylinder and the slave cylinder releases, so the clutch engages itself back (shifting impossible) and won't disengage unless you pump it again. Meaning your master cylinder is hosed. The construction of the slave cylinder makes me think it is not the problem.
Hope they bled it properly.
nothing special really. It's just the old pump and hold technique, but make sure the guy
lets the fluid out carefully and only part of it to not damage seals. Each time the fluid goes out, the clutch pedal drops, so the guy pumping much reach and grab it and repeat. Best to use a low pressure bleeder or mighty vac bleeder on the clutch though since the system is so small and has no restriction (like the ABS and proportioning valves of the brake system)
I think it was $80 to $100 US for the early versions which are aluminum and have an adjustable shaft
The new ones are plastic and fixed shaft probably about the same price. Unfortunately, because of the line fitting, they are not interchangeable. That's US price btw good luck.
Did they replace the pilot bearing??(more)
The pilot bearing supports the transmission input shaft into the engine crankshaft. If this bearing is damaged at all it can essentially fuse the engine to transmission making shifting all but impossible and the clutch seem at fault.
Raise the car and push the clutch pedal...if the clutch fork is moving, then it most likely the pilot bearing. Good luck
JayP
10
02-17-2008 01:01 PM
JMURP
14
01-08-2005 08:36 PM
LosGatosS4
11-02-2001 09:12 AM
