Need help with Air / Fuel Ratio Gauge install
There were instructions a long time ago that said which wire to tap into (if you're using the stock O2 sensor). Basically there is a brown wiring harness with 4 wires, 3 of them bunched up together and one alone by itself. The instructions said to tap into the one that is by itself. I did that. When I turn the car on, the Autometer unit lights up the last greed LED (indicating very rich). It stays on that and does not change.
Did I tap the wrong wire? Maybe the wire tap did not tap the wire? Any ideas? This is for a 1.8T using non-DBW technology (99 model Passat). Any help would be appreciated.
Thanks in advance
mike
Thanks in advance
mike
YOU'LL WANT TO TAP A SIGNAL WIRE, THEY ONLY PUT OUT LESS THAN A VOLT...
WITH THE CAR IDLING, TEST THE WIRES WITH A VOLTMETER, FIND ONE BOUNCING AROUND BETWEEN 0 AND 1 VOLTS, AND TRY THAT ONE. IT SHOULD BE THE FRONT O2 SENSOR, AND DO IT WARMED UP.
dzzeiks
Audi Original "S" Cars
11-08-2008 12:00 AM
Dr. Gräfenberg
07-15-2004 08:26 AM
neonhero
10-17-2000 11:19 PM
