Noticed some wear on the inside of my front tires, I am interested in getting a camber kit
that being said I have heard some negative things about AWE's CPP links. What are some good recommendations? Thanks. BTW, I did get the car aligned after I lowered it.
Here are the specs.
Left front
-1.0 camber
4.8 caster
0.27 toe
right front
-1.2 camber
5.1 caster
-0.56 toe
Wear in the rear looks fine. I have specs for them as well, if needed.
Here are the specs.
Left front
-1.0 camber
4.8 caster
0.27 toe
right front
-1.2 camber
5.1 caster
-0.56 toe
Is this the result before or after an alignment?
Since toe is off badly, I hope it's the "before".
I don't know what the book specifies for the A4, but camber and caster both seem fine to me. With those toe results, though, to drive straight down a road, you'll be turning the steering wheel enough to the left to have the same -0.15 toe-out left and right,
(0.27+(-0.56))/2= -0.15
That's a bit on the high side, and combined with any negative camber, will tend to wear the inside of your front tires.
FWIW, the alignment specs for the S8 front are
Camber: -1.6
Caster: 3.6 (actual, no spec, but more is better)
Toe: +0.1 (+ is toe-in)
I ran 2-1/2 years with these specs, and tire wear was dead square even. At my last alignment, I had toe set to zero.
Camber: -1.6
Toe should be adjustable with the tie-rods; I'd be very very surprised (shocked actually) if it's not on the A4.
You might be confusing this with camber. On the A8/S8, total camber is fixed, but you can adjust how much is on one side or the other by shifting the entire front subframe left or right. For example: 0.0/-2.0 left/right camber can be changed to -1.0/-1.0
the a4 front camber is the same, move subframe to change camber, and you can
only really even it between the 2 sides.
I would recheck the toe, which is adjustable.... you don't have enough camber to affect tire wear THAT much, but toe can mess it up too...
anb957
04-11-2007 03:34 PM
UCLAlumS2K
11-20-2003 06:47 AM
