OK guys...here a quick one for ya. (ATP Dump tube Q)
The wastegate that opens and closes the flapper has 2 nipples on it. The way I have my set up now is as follows. Turbo-->boost controller--> turbo wastegate. Now w/dump tube, Turbo--->boost controller (with a T to run a signal to the dump tube wastegate after the boost controller-->from other side of T to the turbo wastegate). I drove the car tonight and the dump tube isn't opening up. Should I run the line from the BC -->dump tube--> from the other nipple on dumptube to turbo wastegate???
Some insight would be coo..thanks guys.
stupid question, have you tested the dump tube before installing it?
do you have any idea how much boost it requires to open?
If the other nipple isn't capped on the dump tube, it won't open right? Is the other nipple capped?
I was thinking of running a line from the BC to the dump tube and --->
and from the other nipple on the dump tube back up into the engine bay to the turbo wastegate and make a complete circ.
blow into the tube to the dump tube
can you blow through it? I'm wondering if you push boost out of the dump tube back to the wastegate, if it will affect boost. You might have to adjust the MBC if you are going through the dump tube.
Hmm..I'll call ATP tomorrow on my lunch and bug the sh*t outta them
I want this thing to work. The FMIC I finished makes a world of difference (it's all of 54degrees out right now.) It pulls like it's on 100 octane...absolutly nuts!
Now..if I can get the DT to open..should be good for 25-30hp more!!
beejohn
12-06-2006 10:47 AM
Enigma111
08-24-2002 08:38 AM
Silent Assassin
06-22-2002 07:22 PM
BigMouse
04-13-2002 08:20 PM
