ok, where can i get this?
<center><img src="http://www.gcg.com.au/catalogue/Manifolds%20&%20Flanges/g201818%20t25%20exhaust%20dump.jpg"></center><p>dont really want to pay too much for it. its an adaptor plate for Garrett GT25 turbo w/ internal wastegate.
my other option is saturday spent with the plasmacutter and the die grinder on the $40 stainless steel block i bought few weeks back...
TIA
TIA
The best way to do it....
is make a plate with two holes in it, one the same size as the turbo outlet, the other the same as the wastegate outlet.
Run a conical diffuser (7-12 degree angle) from the turbo outlet to the size of your downpipe.
The wastegate would have it's own separate tube that would merge into the downpipe further downstream somewhere.
Check out the PDF link below, it's got some good info.<ul><li><a href="http://www.tantrumwerks.com/html/Split%20DP%20support%20theory.pdf">Split downpipe theory</a></li></ul>
u lucky with your car engine - mine will have a crazy 180 bend followed by 90
<center><img src="http://www.kineticmotorsport.com/data/projectcar/14/20030309-12:02:43-DSCN5988.JPG"></center><p>i guess i gota make something like this, but with better exhaust adaptor plate.
man.. ss bends costs bombs..
Wont help
because the intake side of the turbo must be over there, that setup is for a transverse engine. I also dont think there is enough room behind the engine to even do a dual split pipe.
Well if you can find someone that just sells the rear adapter flange
you might be able to get someone to do the rest. I would try innovative or Forcedperformance, you can also even try APR since their kit includes the GT25 turbo.
