Other than injector CC rating...what other things are there to watch out for?
Right now I have 270CC RC injectors. If I wanted to swap them for Bosch or the like, what other ratings/measures are there that I need to watch out for
Get a set of Mustang 30 lb (310cc) Injectors...
you can get a used set of 8 for about $100. A new set can be had for ~$200, IIRC.
They're high impedance, have the proper connector, and the correct body/o-ring size (the 3 things to look for in an injector)
310cc @ 3 bar is the same as 270cc @ 4 bar.
John...
question for you then. my spec sheet on these injectors list test pressure at 43, and they are delivering 270cc/min.
So...in that situation the mustang injectors wouldn't work I gather
350cc/m @ 60psi...
per Brett at APR.
That's ~ 303cc/m at 3 bar<ul><li><a href="https://forums.audiworld.com/s4/msgs/1091965.phtml">https://forums.audiworld.com/s4/msgs/1091965.phtml</a></li></ul>
