Paging who ever owns this car...
<center><img src="http://pictureposter.audiworld.com/34457/spearco.jpg"></center><p>I would like to duplicate this setup. Info on everything would be great, especially the dimensions/ cost of the spearco intercooler.
Here's my setup
If you have an S4 bumper, and keep the middle grille in, then the shorter IC I have should fill it with no problems.
I had to drain the coolant system the other day, and the IC is now in the way. I was able to get in there with a pair of pliers and open the drain plug, but a larger IC may make it worse, then again, how often do you need to drain the coolant?<ul><li><a href="https://forums.audiworld.com/performance/msgs/51011.phtml">https://forums.audiworld.com/performance/msgs/51011.phtml</a></li></ul>
Whitjr
01-09-2007 04:39 AM
