PES G2 guys: Service interval on the serpentine belt?
How often do we want to change that gator-belt out? I would think that the slightly slip-prone interface to the PS pump pulley would lead to needing to swap it a bit more often.
But then I don't know how often would make sense. Any thoughts?
- Z
- Z
The Bentley calls for 90k, I'll probably do mine every 60k.
That's the interval I've used with my Jeep Cherokee and been lucky so far. I do have a new one in the trunk just in case, since it could fail somewhere that doesn't have that size. NAPA part # 060775.
Well yeah but...
With these cool-o modern belts you don't tend to get much visual indications of problems. And you you do see something at all, you have to take it out. I figure that, overlooking cracks and other outright impending failures, the problem with the gators will be all those little nubs wearing down quicking than normal because of the slip against the PS pump due to the sub-optimal contact angles.
- Z
- Z
pocketmaster
16
01-20-2017 06:46 AM
FourDs
53
06-08-2006 05:40 PM
veryfastS4
25
02-18-2004 10:59 AM
djnelsen
06-19-2003 04:07 AM
Ron
11-22-1999 08:02 AM
