Pics of Ceramic Coated & Ported 1.8T Head.
<center><img src="http://pictureposter.audiworld.com/AudiWorldPics/2000/combch.jpg"></center><p>The Whole Head Surface including the combustion chambers was coated in HPC coating.
Pics of Ceramic Coated & Ported 1.8T Head. on Exhaust side.
<center><img src="http://pictureposter.audiworld.com/AudiWorldPics/2000/xport.jpg"></center><p>All Ports where carefully blended for smooth air passage.
I hope the HPC coating lasts longer than......
the hi temp 2000 degree coating I had them do for the header on my Turbo Lancia. Even though they give it a lifetime gaurantee, it peeled and came off in areas only 100 miles after installation. Keep an eye on it if you can.
I will have my header redone, its a pita to remove. I will go over to the wall and have it "Jet Coated" next time.
Jeff Davison
Jeff Davison
I gues any caoting if improperly applied can fail, just dont want to see...........
chips hitting tha 100K+ rpm of the compressor, not too healthy for the turbo.
A flakey header can be lived with.
Just make sure that the coating was properly applied. Can they give you a gaurantee about a what if?
To be honest, I'm about to lay out $4K for a 16 valve Abarth head for my Lancia (these things are rare and unobtainable) and I will most likely get that coated. Let me know how the HPC works out for you. Also don't forget the dyno numbers as well as exhaust gas temp #'s
Jeff Davison
Jeff Davison
