Pictures of my A4 with rear A8L brakes.
Here are some pictures of my A8L rear brake upgrades:
<a href="http://albums.photopoint.com/j/View?u=1272314&a=9419231&p=32429667">Stock A4 rotor vs A8L rotor</a>
<a href="http://albums.photopoint.com/j/View?u=1272314&a=9419231&p=32851070">A8L rear brake already mounted on the car</a>
<a href="http://albums.photopoint.com/j/View?u=1272314&a=9419231&p=32851129">Side view</a>
<a href="http://albums.photopoint.com/j/View?u=1272314&a=9419231&p=32851064">Behind the wheel</a>
<a href="http://albums.photopoint.com/j/View?u=1272314&a=9419231&p=32851068">My front A8 brakes behind the wheel.</a>
Performance/Price ratio was the major reason...
There are other reasons as well:
1) Easy installation, everything bolts on.
2) You use your stock pads, which means they get replaced for free under warranty/maintenance.
3) Parking brake retained. You loose parking brake with most aftermarket solutions.
4) Both, front (312mm) and rear (269mm) A8 brakes fit under 16" stock sport wheels.
Re: Performance/Price ratio was the major reason...
How can you keep stock pads if rear rotor is 10mm thicker? And what about the mounting brackets- where did you get these- for the front or the rear?
Thanks
Thanks
Because you use different wider caliper.But rotor and pad contact surface remain the same.The bracket from audi by modify with mechining to make it fit A4 and S4 rear mounting point.
Ben the Ben
33
04-06-2006 04:42 AM
nverfollow
17
05-03-2004 07:54 AM
edwardschmedward
07-08-2002 09:01 AM
mattchow
16
02-21-2002 06:17 AM
