is it possible to remove the MAF sensor from that cylindrical housing?
i think i need to bathe mine in isopropyl alcohol to remove some silicon. i don't really want to drop the whole housing in there with it cuz it's pretty dirty.
Re: is it possible to remove the MAF sensor from that cylindrical housing?
There are tamper proof torx bits on it. It's not likely a good idea. You don't want to get anything on the senso itself. There isn't any sense in cleaning the sensor. I gets very hot, and cleans itself I believe. You can carefully clean the housing. Spray a rag and wipe the housing if needed. IF you would need a new one for some strange reason, the same one is used in the 2.0 vw engine, which is readily available at the salvage yard. HTH. Just my opinion on the subject.
Chad
Chad
Monkeyboy
09-02-2006 10:53 AM
When doing a MAF soak, do I need to remove the sensor from the housing, or just dunk the whole thing
Naptown::KckblAlstr
09-21-2004 02:44 PM
T-28-Quattro de VT
11-09-2002 07:12 AM
Singletrack
9
08-19-2002 07:38 PM
