Price comparison of APR Stage III and K04 kit+
I wanted to post this with my original questions answered by MC about the K04 but was unable to do so (out of town for the past few days).
Someone mentioned the costs of the K04 were more than the APR Stage 3 kit. Here's a breakdown (only comparing costs from which I attained from vendor web sites).
APR Stage 3
$4,995 Includes turbo, manifold, hi-flow cat, hoses, injectors and of course hardware/software.
PES KO4 w/extras
$2,195 Includes turbo, injectors, hardware/software
$1,599 FMIC (turbo5)
$ 840 hi-flow cat (turbo5)
$ 269 intake (turbo5)
$ 199 adjustable FPR (turbo5)
$5,092 Total
<i>Notes:</i>
-I left out the exhaust/downpipe because they can be used for each and $ amount depends on what exhaust is used.
-This is just what I've put together with the knowledge that I'm not comparing apples to apples. It is done more for $ comparison.
-The K04 kit can be "pieced together" while the APR kit is a complete kit (AFAIK you can't buy pieces sepperately).
-The hp/torque figures are not provided.
-There may be more options/kits available in the future from a couple of other tuners.
It would be nice to see a complete test session (dyno, 1/4 mile, drivability, objective, etc) with a couple of different setups and compare.
-Don
APR Stage 3
PES KO4 w/extras
$5,092 Total
<i>Notes:</i>
-Don
Here is a fair comparison for price.
Why would you compare a stage 3 with NO IC to a Ko4 kit WITH an IC?
Lets compare "kits"
Complete Ko4 kit = $1649 230hp (tested 238)
Complete Stage3 = $4995 280hp (claimed)
Difference = $3346
Stage 3+ $6999(clutch needed at $1400 extra plus install)
Ko4 with IC = $3244 (stock clutch is fine, drag racers would want to upgrade down the road).
You added in an Intake kit and a Cat down pipe. Both APR's kits use the stock box so for price comparison you should not add an intake. The Ko4 kit does include a 5bar FPR and does NOT need the adjustable unit. The adjustable unit is only for die hard tuners that want to fine tune fuel trim.
The Cat and down pipe is not needed but is offered as an upgrade. APR must provide one as ther turbo flange and mounting is different. I did not add one to either Ko4 setup as its not mandatory that you run it.
*note*
I am not flaming for either kit. I am purely correcting price points that where posted above.
I have stated before that we should not even compare these kits. I felt that I should post real world cost's for each setup. You decide which one you want based on your goals and your wallet.
Clark
Lets compare "kits"
Difference = $3346
*note*
Clark
Good points, what I was thinking and why
Clark-
Thanks for the response. You're correct, I wasn't comparing straight kit to straight kit but I wasn't trying to. I was trying to compare the costs of a possible 250hp K04 setup to the cost of an APR StageIII kit.
After your posts to my questions from last week(BTW, thanks), I started outlining some costs. I wanted to see a cost/time/option layout for getting 250hp/280lb/ft from a K04.
You mentioned, "Cat/downpipe/intake/exhaust/adjustable FPR/ported manifold = 251hp-283ftbls." When HJB mentioned in that earlier thread that a 250HP K04 might be the same price as a APR Stage III, I just put together a post with the costs.
For now I'm tossing some ideas/options around which may become moot when I actually purchase (with other kits/options coming). I know the old saying "How fast you want to go is equal to how much you want to spend". I just want to know as much as I can before spending.
You're right, these kits shouldn't be compared "kit" vs "kit". For now, I am weighing options to what I currently have which is nothing more than stock+chip+exhaust.
BTW, thanks for all the information you have provided. Your K04 setup sounds strong and proven and has been motivation for me in looking at options for my car (hence the questions and posts).
-Don
-Don
Thats prob not far off.
The IC is the single largest power adder after a Ko4 kit. Not only do you gain peak power but you KEEP that power longer.
Remember that my 251hp Dyno pass was with a chip that makes 15 PEAK psi. only 13 past the midrange. Its a great setup. Take the AWE ko4 kit for example. That is sold with 30b software. You would get 17-19psi in the midrange and not as much boost fade up top.
I made that 251/283 with a low boost chip. Less boost that a chipped Ko3 car. With more boost I would estimate 300ft lbs at 260 hp. This would be the limit of the Turbo and its run very hard.
you can see the effects of my IC and the rest of my mods when I make that much power on only 15 lbs..
Clark
Clark
You Cannot compare the two kits.
Two totally different setups...
K-04 gives only a little more Go between 5500-6500 rpm mark.
Down botton is similar to a stock k-03 turbo.
The GT25 setup, is heaps more torque in the 3000-5000 mark, Buckets more, drive them both...
The APR kit, still have a upgrade bath... Bigger turbo, more HP, and may leed you into to 350HP+ bracket.
The K-04, has had problems, 240HP seems to be the maximum limit, any more time will tell how long it lasts.
The K-04 is a small turbo and to produce 240HP is really maxed out, a little more may be gained, but you are pushing it far and beyond its limits.
I have had 2 K-04's (both Failed) now have a Garret GT25 setup, never looked back.
Even the best perfomance of my ex-K-04 is not a shade on the GT25 setup.
Decide carefully where you want to go with your car...
Well Said...
Both are differnt Kits, depends on what you are looking for.. 5000, might be too high a price for some people. And a 1500 Ko4 kit might be what they are looking for.
Acording Someone i have spoken to, a Ko4 with a Garret chip, topped out at 225 hp.
They did not say what software they where using, or what the certain problem was.
They where using a dyno.
