Q: Vibration while braking (not warped rotors, x-post)
Hello. I have been trying to diagnose a vibration while braking. It's not pad deposits or out-of-true rotor. It's worse as the brakes get more bedded in and/or warm.
Seems to be coming from the front right (as it gets better right after I replace that rotor, then slowely gets worse).
I don't have any noticable whirring noises (other than normal s4 tire noise w/wear), and a tiny vibration when not braking (which could be the snow tires or wheel balance).
It has become more pronounced since non-floating calipers were installed, but did do it with the original rotors/brakes, especially after time and warming up.
I'm thinking a bent hub or bad wheel bearing. Car has 60k miles on it. 1 Year ago I smacked a wicked pot-hole that bent the wheel (now the spare) and flatted.
Thoughts? Comments?
Thoughts? Comments?
Tire belt slippage? Bad bearing will just start to make noise...
I would still look at the rotor. I have had many that looked great, that would vibrate with increasing force when driven hard (superheated!).
Swap tire. Switch rotor.
"Swap tire, Switch rotor." I agree. Bent wheel is my guess...
and maybe the hub is out-of-true where the rotor and wheel mount. You could remove them and check lateral runout with a dial indicator if you have this kind of equipment. A good shop should be able to do this. Compare readings with left front which you said doesn't vibrate.
My $.02
My $.02
runoverb4
17
11-28-2007 11:50 AM
moving violation
04-24-2004 01:54 PM
NEPaNogaro
04-03-2002 02:00 PM
gesTTalt
03-12-2002 09:20 AM
