question about intercooler tube size.
I made my own hard pipe for the intercooler on my a4 and I was thinking about redoing it in 2.25 or perhaps 2.5 size tube. right now I have 2 inch on the car and everything seems ok. i have pics of how i set up the fmic in my pic poster if anyone wants to check it out. eveything is tig welded and seems smooth on the inside. I think the stock intecooler pipe is about 2 inch so with my apr stage three perhaps I should go larger.
would i notice any power gains or faster spool by increasing my FMIC tube to say 2.5??
thanks
thanks
Your spool up will be slower with larger size tubes.
Just remember that the more volume there is the longer it will take the turbo to fill up. This means you add a delay to the air flow hitting your manifold. The only time you want to increase the size of anything is when it because a limit to how much air flow you can move.
There are a lot of trade offs and balancing in proper IC system design.
Air moving too fast may not remain in contact with the cooling surfaces enough to transfer heat properly. Too slow and you lose pressure. There's a sweet spot for each system of trade offs that will favor a particular engine's air requirements under a certain range of conditions. It's a lot of trial and error even starting with cores and tanks of recognized superior design (although you're a lot closer to start off with such). Audi even uses a wind tunnel for IC R&D. Set up a system where you can test air/intake/outlet temps and pressures or you'll never know for sure. Happy experimenting!
Not going to see any gains unless your tubes are too small
to handle the CFM your turbo makes. The larger the tube the longer it will take for your turbo to pressurize them, causing a slight delay in power.
ImQuattro®
Audi Original "S" Cars
14
04-28-2007 12:05 PM
bertworks(dan@jhm)
12-09-2006 12:41 PM
