Question on air intake temperature...
I logged block 004 which I think is the intake air temperature. I held pretty steady on 78C Celsius on a 30 minute drive. Is it a normal temperature?
Mau
Mau
Re: You must be looking at the coolant temp...
So the first block is coolant and intake temps?
I remember one of the readings being in the 30C's. Btw it was about 80F outside when I looked at block 004.
I think block 004 is Revs, Voltage, Coolant temperature, Intake temperature.
30 C is ~86 F and that is not surprising . .especially given a 80 degree day. I think you are likely to see IATs in the low 30s just crusing around and IATs in the upper 40s or low 50s if you are really on it .. w/ a FMIC.
