question for people with intakes...
what did you do with that little breather hose? i was thinking of trying to get a small filter, like one of the ones used on the filter bypass...any suggestions<ul><li><a href="http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=35572&item =4528902038&rd=1">kinda like this</a></li></ul>
the inlet in that breather looks a bit small for the smog pump tube
I have an autozoen breather which is bigger than that, but still too small. I just wrapped the inlet in tape to make it fit.
Re: yea that one was tiny...for now i cut up a stock filter and made a "hood" thats duct taped on...
Did the same. Taped it up and stuck it on.
BTW, saw your earlier post in the C5 forum and I'm kinda with you on the intake temp. I'm using the BMC CDA filter with custom piping which connects to the OEM air ram.
im thinking ill build a heat shield before summer shows up and some type of ram(+)
...i was thinking of cutting a little peice of the fan shrowd away which owould direct a lot of air to the intake...
Zwoobah
Audi Original "S" Cars
9
06-21-2007 05:12 AM
