Question for those with a fuel pressure gauge in their cars...
Audiworld Sponsor
Does the fuel rail hold system pressure overnight or does it drop off? Let me know the year and model along with your response, if you could.
Thanks.
-Dave Pramanik
Thanks.
-Dave Pramanik
It drops to zero after some time.
This happens because there is nothing to hold the pressure in the fuel system and it drains back to the tank. When you turn on your key the ecu sends a pulse of power to the fuel pump so that it builds up some pressure before you start it.
Audiworld Sponsor
Thanks.
I was told that it should hold pressure overnight, but mine wasn't... was concerned I had a leaking injector.
The fuel pressure seems to drop off gradually over a period of 2+ hours. Sound normal?
Cycling the ignition brings it right back up.
-Dave Pramanik
-Dave Pramanik
See pages 24-8 and 24-95 in the link
This is for the AEB but I suspect similar for the DBWs ...<ul><li><a href="http://1.8t.org/~quattroman/Audi%20B5%2097-2001/Fuel%20injection%20and%20ignition/AEB/MFI/24-1%20Motornic%20MFI%20&%20Ignition%20system.pdf ">http://1.8t.org/~quattroman/Audi%20B5%2097-2001/Fuel%20injection%20and%20ignition/AEB/MF
Audiworld Sponsor
Mine definitely holds pressure for more than 10 minutes...
Takes a few hours before it drops down to zero. Just wanted to confirm that it was supposed to drop off and not maintain pressure over time.
Sounds like what I'm seeing is normal.
-Dave Pramanik
-Dave Pramanik
