repost: help with this code please.... 17884 Evap Leak Detection pump insufficient vacuum...
i'm only hitting 17-18 psi. any suggestions on what i should check first? thanks.
from bentley...
... it could be a malfunction with the Evap system or insufficient vacuum. You can run the evap system with the output diagnostic from vag-com.
If you have an aftermarket exhaust you could have a problem with the vac line going to the evap system in the rear, touching/melting against the exhaust.
Otherwise, start looking for vacuum leaks.
I'm in the process of looking for a vacuum leak right now.
Kirk
Kirk
woods4
02-27-2008 06:00 PM
J.Leezy
01-02-2008 01:10 PM
VTstage3a4
05-26-2003 02:15 PM
redsac
07-09-2001 08:04 AM
