RS4 clutch in an S4....
I'm gonna put the RS4 clutch (well, pressure plate, since the clutch discs are the same on the S4 and RS4 - but I'm getting a new clutch disc as well since mine is pretty worn , and I'm wondering if I need to order any other parts, aside from the disc and pressure plate?
Thanks
-T
Thanks
-T
normally I replace the rear engine seal, the pilot bearing and the throw out bearing but that's when
the car has over 100k miles on it. You'll probably be ok without replacing them.
Make sure to bleed the clutch slave. It's a PIA to get to because of them turbos.
Cool stuff. Hope it works out well
Hmmm, maybe someone in Europe can call their parts department. They're typically generic even....
accross car makes. The throw out most likely will be the same since they have the same tranny housing. The pilot bearing depends if they have identical flywheels or at least the flywheel bore for the bearing.
Funkweasel
17
08-02-2004 09:22 AM
Vijay
Performance and Tuning
06-15-2002 04:54 PM
