SameerP, or others running a test pipe. What sort of difference did you notice?
I love it so far, though i need to do some more testing...
the big difference is spoolup. I went from spoolup at 3500 to spoolup at 3000! The sound is great on a test pipe, just deeper and throatier. In terms of flow, car feels extremely open, if that makes sense, at high revs now...5-7k is beautiful and relaxed, with massive power.
I paid labor for the thing to get put on same time as a Milltek...i know you seem to do alot of the work yourself...but its a bit of a PITA.
The test pipe is only like 150 from Brett (OneEight) so id definitely recomend it.
Cheers,
Sameer
Cheers,
Sameer
does the check engine light stay on?
i was looking at getting a test pipe a while ago to see what kind of increases i would see on a K03, but didn't want to have to deal with the check engine light. I read recently that you can get a chip from GIAC that is a off-road use only chip that eliminates the use for the second o2 sensor, is that what you are running? (for $150 i think it would be worth trying)
I could swear i see 20psi at 3000rpm.
like i said, i need to test more...but i feel like full boost is there by about 3100 rpm, not at 3600 like before.
Put another way, i think a big part of ARR S3's low end grunt is due to their HFC...
Cheers,
Sameer
Cheers,
Sameer
yes CEL is on...i will get around to fixing it...
there are resistors and emulators you can buy to wire in line to fool the second O2.
I never heard about this GIAC chip, ill have to ask.
Cheers,
Sameer
Cheers,
Sameer
Likely that is a part of it but the GT series turbos do spool faster due to the better aerodynamic
design of the housing, the turbine and, of course the BB helps some too. I wouldn't expect a HFC or test pipe to drop a full 500-600 rpm to the spool up & boost peak. I'd expect to see a couple of hundred tho ...
BTW .. Told ya you'd like a HFC or test pipe =p
Yes it is about 100-200 with a HFC or race pipe, but it will help even more on the top end
over the stock cat which has too much back pressure at high rpms. To drop 500-600 rpms he would need a 2 liter motor to spool up the turbo that quick.
Sameer, I used to have a straight pipe with the T28 and it never hit that soon. A straight pipe will change how fast the power comes on which is called lag. The pipe cant increase flow at low rpms before the turbo.
I hear ya, its just reinforcement of the HFC as a good part of the kit...
now just get a 3" MAF in there!
I need to test more to determine. Clearly from 3k on the car is *alive*...the hard hit at 3500 has become a big roll on from 3k on...and the top end is fierce, but remember i also went from a Borla to a Milltek, so unfortunately i cannot appropriate between the two.
This weekend ill do some runs and see exactly what im seeing, i realize Mike's comment about spoolup...
As for the test pipe, no soot on bumper, no flames...sounds nice...i figure this fall ill do the cat project.
Cheers,
Sameer
Cheers,
Sameer
