Sending turbine housing and manifold to HPC - should I send cat also?
I'm sending the turbine housing of my T3/T04E to HPC for the hi-temp coating along with the new manifold. Anyone ever coat a cat? Is this a bad idea for some reason?
TIA
Mike O.<ul><li><a href="http://www.hpcoatings.com/exhaust_coatings.htm">HPC - Extreme Coatings at bottom</a></li></ul>
TIA
Um, no, or you'll cook the cat. (m)
The cat needs to dissipate heat. Any heat retention past the turbo is of no benefit. If you want to reduce the underhood temps due to the cat, relocate it out of the engine bay.
Mat Indukts Lambos
06-19-2003 07:25 PM
AUDIOZ A4
05-22-2003 05:30 AM
