SKS EMAIL ME PLEASE!! or anyone else thats installed their mounts using his instructions!!!
i just tried to install my motor mount with your directions and there is no possible way to slip that damn mount inbetween the nub on the radiator side and that *#@$* plate thats in front of the oil pan!!! i cut my stock mount and now im without a mount!! please help!!!
i cant remove my front bumper cuz i was in an accident and my hood wont open.. does this mean i gotta wait until my car goes into the body shop??
ARGH!!!!!!!!!!!!!!!!!!!!!
Ok... here ya go.
I looked at mine up close again today. The back plate is held on with some brackets. Remove those bolts. You goal is to get it free. Loosen the belt tensioner so its out of the way. You will then be able to slide it in. I used a long screw driver to gently pry it in. Since I coated mine with lithium grease it slide in with no problem.
Clark
Clark
I tried you on aim but you where not on.. Here is a blow up shot of the front of the engine.
<center><img src="http://www.turbo5.com/gallery.php?displaypic=MC%40turbo5%2FBlowup%2Fmoun t.jpg&non_lr="></center><p>Hope this helps.
Clark
Clark
I wonder why there are so many vibration complaints...it would seem that
you'd get lots of vibe it items 7 and 8 were firmer...those Hydro Mounts as they're called...cause thats the direction the engine wiggles in when it's running?
How bad is the Vibe in reality Clark?
Regards,
James R.
2001 A4 1.8TQMSXP (Oettinger Pedals, Oettinger RE's 17x8 Yoko AVS Sports 225/45/R17, Euro Xenon Housings, Bailey BPV, Turbo5 Intake and RS4 Grille)
Regards,
James R.
Info..
When stock my car was like yours. A numb wheel and almost no vibration. Very smooth and quiet.
With the mount my wheel shakes and vibrates as well as my door panels. Only the lower RPM range is where the vibration is. Example: Turn the AC on and its the worst.
Anyone that has owned an A1 or A3 Volkswagen will know exactly what this is like. It reminds of of my Sirocco.
I dont want to scare anyone off. Its not that bad but there is more vibration for sure. Sometimes I hate it. My Dad was in town last week. He has owned many Audi's. He drove the car around. He made a comment "this is not the smoothest engine I have seen". I told him about the mount and he agreed. He said "before the mount you had to look down to see that the car was even running. Now you know it." I agreed.
As I said before. At this point I like the mount and I am willing to accept the trade off. I like the solid feel. If I stopped drag racing I would yank it out. I see no point in having it unless you want or need that driveline located better.
I used to have a mount for the side of my 1.8 in my Scirocco. I cant remember who made it. It had cutouts on the edge of the donut to allow some flex. That mount worked real well and added little vibration be still had a solid feel. I wonder if that design would work on this application.
Clark
Clark
dual composition!
hard inner core with more flexible outer ring.
flexible section cuts out most vibration (higher frequency stuff), while the hard section ties the driveline together.
I bet Energy Suspension has something on the shelf that would work (ok, so I'm guessing). But Clark could get Turbo5 working on that project? Sell it for $120...I'll be your first customer (assuming I can get the APR mount off).
steve
steve
Well no, because the hard center would do the driveline stabilizing...
...whereas the soft outer part would take away some of the vibrations (higher freq. vibes as steve said). The lower freq. stuff is the driveline flex we don't want.
I'm sure that this would be better than stock, but not quite as good a full solid mount. Everything's a compromise I guess.
Ash
Ash
Allroady DungBeetle
06-11-2006 05:32 AM
For those who were asking : You can change a motor mount (snub mount) w/o removing bumper/radiator..
Chuck-S4
10
07-14-2004 01:38 PM
ConeKiller
19
01-02-2002 10:21 AM
hurricanesteve
02-20-2001 09:49 AM
