Performance and Tuning Discussion forum for various performance tuning techniques and questions
slave cylinder...
Old Aug 22, 2004 | 01:45 PM
paulroad's Avatar
Tech Guru
Default slave cylinder...
We just did a 1.8t engine transplant. All is OK. but the slave cylinder on the clutch, after one day...blew.
We replaced the cylinder and after a few hours of town driving it blew again.
Any Ideas to track down?
Old Aug 22, 2004 | 02:28 PM
Yippers®'s Avatar
Member
Over stroking it? Are you sure you have the release bearing assembly properly installed?
Old Aug 22, 2004 | 03:57 PM
Phil type 951's Avatar
Default see if you can get a metal one from 2.8 trans,
the slave that came with my 2.8 trans was metal, cast alum i think. I dont know if they are all made of plastic now but its worth looking into.
Old Aug 22, 2004 | 04:26 PM
paulroad's Avatar
Tech Guru
Default Over stroking?
Can you elaborate? I thought the slave was pushing on the clutch lever? Am I missing something? The car is shifting fine..pedal effort is normal.. then one one push...squish.....
Old Aug 23, 2004 | 12:17 AM
dan farmer's Avatar
Senior Member
stock clutch, throw-out, and flywheel? or aftermarket?
Old Aug 23, 2004 | 02:56 AM
paulroad's Avatar
Tech Guru
Default all after market.. swapped from the blown engine to the new engine
blown engine never had this problem in 10K miles...
Old Aug 23, 2004 | 07:40 AM
Audiboy's Avatar
Where's your pedal engagement? Is it low? Sounds like it is overstroking indeed
Old Aug 23, 2004 | 07:47 AM
paulroad's Avatar
Tech Guru
Default Car is going back to mod shop...(Quattromotion)
They will take a look at their own work and re-do what is needed.
Old Aug 23, 2004 | 10:23 PM
dan farmer's Avatar
Senior Member
Default There have been recent problems on S4s with aftermarket flywheels and t/o bearings. Parts varied
from stock dimensionally, allowing slave cylinders to pop their piston. Three engine-pulls later, the tuner went to an RS4 set-up. Works fine.
-df
benjaminws
Nov 15, 2011 10:02 PM
Zzak
Mar 2, 2005 07:20 AM
xcosx
May 11, 2003 11:19 AM
Rob K
Jan 18, 2002 11:36 AM
RayE
Oct 23, 2000 09:18 AM
