So what comes after a broken easy out? :-)
When I was tightening down the turbo to DP connection, one of my studs on the exhaust side of the turbo decided to snap...Great, just what I needed. I pulled the DP off and thought about how to solve the problem. Since there is no gasket there apparently, I don't trust having just 4/5 bolts to create the necessary seal. Luckily, I thought that this stud would be the easiest to access, so in that case I am fortunate. It is the upper one closest to the manifold if you are wondering. So I went out and bought a trusty tool. I didn't see anything that said easy-out on it, but what I ended up with is a Hanson spiral screw extractor that says it "removes broken bolts or screws". Okay, so I drilled my hole, got the extractor in, and was set. I started trying to turn the damn thing, no go. I decided it was time to go out to the hardware store and get a tap wrench, but they were all sold out/closed by the time I got there. I remembered that a crescent wrench might do the trick and I hadn't yet tried it, so after about a half hour with it and evidence that this tool is stronger than my forged chromium crescent wrench, I am left with a stud still in the turbo, but now it has the tip of the screw extractor, too. So my question is, whats next? Should I try to drill another hole? With what type of drill bit? I wish I could just weld, but don't have access to a welder, and the car is not moving. Any advice to seperate the extractor from the stud. Theres not anything to grab onto, and my attempt to turn it clockwise with a drill didn't do anything to free it. Should I try a left hand drill bit? Any thoughts? Also, so this doesn't happen again, anybody have a torque spec for a turbo/DP connection?<ul><li><a href="http://www.mytoolstore.com/hanson/extractr.html">Here is the tool that I bought EX-2</a></li></ul>
You'll never be able to drill the easy-out.
The only way to grind off an easy-out is with a carbide rotary file on a high speed grinder.You need to heat up the housing till it's red (not the stud,in case you don't know) with small torch and you'll be able to unscrew it.
Mr. Head
12-11-2006 06:34 AM
Solaris
11-05-2006 12:52 PM
OCquattro
11-15-2005 10:57 AM
