Spring/Shock/Swaybar combo Advice sought
I have installed H&R CO's (S4), a Neuspeed 19MM rear sway bar and S-03's on 17 inch rims.
The car handles nice.
Anybody out there installed a front sway bar? What size? Did you pick up much push?
Adding a larger front bar will increase understeer... unless you go with a smaller-that-stock bar.
Sounds like you have done all you need to do to make the car handle in a more neutral manner. Adding a front bar will make it understeer just like it did before you spent all that money on coilovers/rear bar. Unless you WANT the car to push... but then why do all the work you have already done???
Skip it and spend the money on a driving school or high speed driving event ilke the one in the link attached.
PeteH<ul><li><a href="http://www.thedriversedge.net">http://www.thedriversedge.net</a</li></ul>
Wondering about balancing things a bit
The 17mm rear sway bar really tightened it up, to the point of letting the rear end come right out with a little trailing throttle.
It almost seems like it is pitching too much to the outside front in a turn, that it could stand to take a little less of the load.
Hence my question. Right now it just has the stock front bar. I was thinking about going to the sport front bar. Might just try it for grins anyway. I can't imagine that the current front bar is affecting much of anything.
nogaro*blue*you*away
17
08-20-2006 05:50 PM
DenverAvant
06-12-2005 02:35 PM
