started the car after T28 install.....really rough idle, no codes. any ideas?
gonna try different injectors and FPR, but has anyone seen these symptoms before?
thanks
Liam
thanks
Liam
my Stage III did the same thing...
That was before I found and fixed several vacuum leaks. This might be your problem too.
If you let it run for a minute does the idle fix itself and start going smooth again?
Re: started the car after T28 install.....really rough idle, no codes. any ideas?
Sounds like the ECU will adjust and it will run smooth after a bit.. Checked your plugs lately also??
Thats what mine does... Did finding the leaks fix it?
I just think that this is strange because I've replaced all of my piping from the turbo to the throttle body so there shouldnt be any leaks. How did you find the leak?
nDBW. so far found a faulty FPR. gonna change that later. thanks for the input guys
WYSIWYG: you were right, injectors were also bad, (but car didnt start) put in new ones already.
will keep you all posted.
Liam
Liam
