Performance and Tuning Discussion forum for various performance tuning techniques and questions
Starting off the line
Old Dec 29, 2000 | 12:37 PM
Lac Vo's Avatar
New Member
Default Starting off the line
I have a 2000 A4 and want to ask a for some advice. I'm trying to get off the line as quick as possible. When I'm about to start, I rev the engine to about 4000 and then let go of the clutch. The car jumps very quickly and then the engine rpms drop down and I lose all power. What am I doing wrong and what is the proper technique to get a good start with an A4?
Old Dec 29, 2000 | 12:42 PM
Lucas_Gchips's Avatar
Keep doing that and you will need a new transmission..
Old Dec 29, 2000 | 04:44 PM
CMH's Avatar
CMH
Senior Member
Default It is easy. Pull the clutch up to the friction point, then rev up to 3500. As you let out the
clutch you will then what to go WOT. The problem you are seeing is the DBW seeing the driveline shock, it will then pull all the boost from the car by opening up the wastegate. It will also do this when you try to speed shift if you dont let of the gas a little.
Old Dec 30, 2000 | 07:14 AM
Lac Vo's Avatar
New Member
Default Re: It is easy. Pull the clutch up to the friction point, then rev up to 3500. As you let out the
What does WOT and DBW mean?
Old Dec 30, 2000 | 07:30 AM
Shoe's Avatar
WOT= Wide Open Throttle DBW= Drive By Wire(in 2000+ A4's)
podigoto
10
Aug 26, 2012 10:17 AM
Redneck Truck
13
Apr 6, 2011 07:13 PM
mm
Mar 5, 2004 11:49 AM
computrtutr
Oct 9, 2002 04:26 PM
Mirror|rorriM
Sep 16, 2001 08:24 PM
