Suspension Problems continued...now with pics
<center><img src="http://pictureposter.audiworld.com/19076/side.jpg"></center><p>As some of you know, i recently lowered my car with eibach/bilstein and it ended up lower in the back then front, eibach has addressed the issue with a 10mm rear spacer for all 100/s4/a6/s6 kits, however i dont think that will cut it for me...here are some pictures and some data....how big a spacer should I have fabricated? (please account for possible settling and the fact that lifting the rear may (?) push the front down a bit), any help would be greatly appreciated
DATA:
Center of
Wheel to
Fender lip
FL - 14.25"
RL - 12.6"
dif (1.65)
FR - 14.5"
RR - 12.6"
dif (1.9)
FL - 362mm
RL - 320mm
FR - 368mm
RR - 320mm
Ground to
Fender Lip
FL - 25.8"
RL - 24.5"
dif (1.3)
FR - 26.1"
RR - 24.5"
dif (1.6)
FL - 655.4mm
RL - 622.3mm
FR - 663.0mm
RR - 622.3mm
DATA:
Center of
Wheel to
Fender lip
FL - 14.25"
RL - 12.6"
dif (1.65)
FR - 14.5"
RR - 12.6"
dif (1.9)
FL - 362mm
RL - 320mm
FR - 368mm
RR - 320mm
Ground to
Fender Lip
FL - 25.8"
RL - 24.5"
dif (1.3)
FR - 26.1"
RR - 24.5"
dif (1.6)
FL - 655.4mm
RL - 622.3mm
FR - 663.0mm
RR - 622.3mm
hacksaw : P
putting spacers on the rear will raise the rears, which could lower the front maybe by a millimeter as weight redistributes.
As springs sag, maybe another 3 to 6mm in time, I am willing to bet your rears sag more than the front which will make your situation worst.
Coil overs are definetely more expensive but will help you fine tune your rideheight either for style or performance. You can ask if they have a short spring for the front. Check the front Bilsteins also to see if there are grooves below the lower spring perch. If there are, you can used them to go lower.
Or you can just grab a hacksaw and nip a quarter turn from the front ;P
your kidding right? lol..
id never cut springs, and no im not a millionaire so i cant afford to just throw this new suspension in the garbage and buy new more expensive coilovers....im a 20 year old college student, it was a strech to buy the eibachs and bilsteins!
wont spacers do the trick?!?!?
before pic. seems to show drop in rear also...
Car appears to sit low in the rear to begin with. May not be the spring kit problem but I would definitely have a specialist measure and add appropriate spacers or modify mounts.
