Performance and Tuning Discussion forum for various performance tuning techniques and questions
Is there a mathematical way to figure your gain per lb. lost?
Old 12-11-2000, 10:24 AM
New Member
DawnMC's Avatar
Default Is there a mathematical way to figure your gain per lb. lost?
I can't find anything in the archives that shows how much a lb. is worth...
For example, pull out the front passenger seat (no, I'm not doing that, this is purely hypothetical) and it weighs 90 lbs..... what kind of gain do you get for that? I know every pound counts, I just don't know how much.
Old 12-11-2000, 11:09 AM
New Member
Kevin K2's Avatar
Default Re: Is there a mathematical way to figure your gain per lb. lost?
roughly:
wheel hp = (200 x wt)/(ET)^3
so acceleration wise, drop 3% weight is like adding 3% more hp, roughly.
Old 12-11-2000, 01:00 PM
New Member
ottobahn's Avatar
Default Grab the latest issue of Sport Compact Car...
...the article on the cover goes into serious detail about this.
And to add my meager 2 cents:
On a sub 2000 lbs car, I would make an effort to lose weight, but on the A4, there is no reason. All the wiring, undercoating and sound-deadening (sp?) material weigh too much. But that is why I like it, it is quiet, things happen at the touch of button and it will not rust. Unlike my old GTV which I got down to about 1800 lbs and I could tell a major difference with a full tank of gas and was a very unfriendly daily-driver.
Old 12-12-2000, 06:32 AM
New Member
Augie's Avatar
Default Yup...
...assuming you're speaking about acceleration. The performance change is equal to the cube root of the power-to-weight change. Therefore, if you lose, say, 3% of the vehicle's weight, you can expect an improvement of about 1% in acceleration, over, say, a quarter-mile. As an example, a 16 second @ 85 mph car would have the potential to go about a 15.85, at just under 86 mph.
Adding 25% power (such as a chipped S4) would have the potential to improve acceleration by about 7.7%, meaning a 14 flat at 98 mph car might be able to go 13 flat, at about 105.5 mph.
Old 12-12-2000, 08:15 AM
New Member
Dr. Mike's Avatar
Use 234 rather than 200 for the correct proportionality constant. NT
normbi
S4 (B8 Platform) Discussion
12
07-03-2012 10:22 AM
Kgnast-Nemo4.2
10
08-01-2003 05:30 PM
ZGTT
13
07-01-2002 10:19 AM
Merou
20
06-25-2002 02:57 PM
GeoS4V8
9
08-11-2001 11:56 AM
Quick Reply: Is there a mathematical way to figure your gain per lb. lost?
