Thoughts on Spec stage II clutch? Is the piece quality and reliable?
Re: Thoughts on Spec stage II clutch? Is the piece quality and reliable?
nope, spec clutches are **** dont waste your money. contact audi2ptzero and he can get you a werks of art clutch in different stages to fit your driving needs. it is also IMO way better quality and very reliable.
Dont know how they work but we did clutch 3 times in 2 days because what they sent didnt fit!
So I wouldnt touch the company with a 50 foot stick. They kept sending replacements, but it nearly broke my back doing all those changes in the time period I had to get it done. I was just lucky the Sachs was sitting around waiting on another car.
I ended up using a 2500$ Sachs racing, and it is holding 550 crank with no problems and holds 6000rpm launches and is daily driven. Pricey, but it is best I have used even on the V8's I used to play with - good blend of driveability and holding power. I am now on 2nd one in 2 diff cars, urs4 1st then the a4. Very hi quality pieces and no limits I can touch yet.
Rod
Rod
Run away
Terrible Customer Service. Terrible. Terrible. Terrible. Terrible. Terrible. Terrible. Terrible. Terrible. Terrible. Terrible. Terrible. Terrible. Terrible. Terrible. Terrible. Terrible. Terrible. Terrible. Terrible. Terrible. Terrible. Terrible. Terrible. Terrible. Terrible. Terrible. Terrible. Terrible. Terrible. Terrible. Terrible. Terrible. Terrible. Terrible. Terrible. Terrible. Terrible. Terrible. Terrible. Terrible. Terrible. Terrible.
I didn't use a Spec setup, they simply machined mine down a bit and sold me some new Sachs disks.
That part was okay, but I had to ask for my old Audisport disks back.
The problem is their customer service. No return calls and very slow. They charged me for 2nd day shipping and said a quick turnaround within a week so I 2nd dayed my bad clutch to them. Actual time was over 2 months and they shipped ground.
BTW< everyone else I know who ordered a Sach's clutch for their Audi got the wrong thing the first time around.
Strange...
I had a Spec stage 3 clutch on my car about 2 years ago and had zero problems with it... Everything went smoothly the first time around and I received great customer service. Its sad to hear the company has gone downhill recently as I really did like their product.
Re: pays to investigate b4 buying as im sure you know, Sachs gives correct part #'s dont expect dick
<center><img src="http://www.bufkinengineering.com/reclutch01.JPG"></center><p>
Yeah, I had to choice. I already had the 2 disk racing setup and I was told Sachs had disks. To be totally safe, I sent them my flywheel and the entire clutch assembly so they could test fit everything.
Without calling me, they machined done my flywheel.
I had to drop the tranny twice to get the setup to work. Also had to machine a longer clutch slave throwout pin and a delrin spacer for the throwout bearing.
THe only good thing is the new disks are awesome (Sachs C1 200mm 4 pucks) and the clutch will hold something like 650 ft-lbs. Replacement C1s are not that hard to find.<ul><li><a href="http://www.bufkinengineering.com/rebuiltclutch.htm">http://www.bufkinengineering.com/rebuiltclutch.htm</a</li></ul>
