TT 180 engine vs. 225
Could someone clear up what makes the compression different between these two? I'm assuming that the head of the 225 has more volume since the bore & stroke are the same. This seems misleading to me since they're both called the same 1.8L.
Am I clueless here?
Thanks, Jeff.
Am I clueless here?
Thanks, Jeff.
The easiest (and cheapest) way to drop compression....
is to add a thicker head gasket. I'm not sure what the two compression ratios are, but you can drop quite a bit, depending on the chamber volume and piston dish.
Nope, that won't change the compression ratio....
and the stock 1.8T rods from my 97 1.8T were forged, most connecting rods are.
The following 4 things will affect the compression ratio:
1. displacement (volume)
2. piston dish/dome volume
3. combustion chamber volume
4. head gasket volume
any change in those four areas, will change the compression ratio.
Tried and true...
There is no engineering reason not to do it. It is done all the time by factories and racing teams. The advantage is that you don't irretrievably mill off head material and it gives you a safety margin if you overdo the boost.
