What kind of problems will a bad front 02 sensor cause?
I just found out my first one is bad and I was wondering if I should replace it right away or if it could wait a little while. I think it may make the car run a little rich but is there anything else I need to worry about?
So basically it will be very rich???
Is there any chance I may be able to clean it off to help it have better readings again? I was driving the car for a while with out MAF and a massive boost leak (the charge pipe wasn't on the turbo) which may have coated the thing in unburnt gas. I'm probably wrong but it may be possible...
Re: What kind of problems will a bad front 02 sensor cause?
Since the ECU is probably seeing a signal which is 'out of spec', you will most likely run rich. Probably quite rich. Self-preservation mode.
Replace it.
Replace it.
Re: So basically it will be very rich???
Not really. The O2 sensor compares the content of the exhaust stream with that of the air outside of the exhaust - ie, in the engine compartment.
Once they go, they are gone. Especially if the top part of the sensor is polluted with any type of chemical - coolant, fuel, etc.
Replace it. They are cheap.
chris1
06-24-2008 08:15 AM
byron - b'rizzle
20
06-24-2003 02:08 PM
Ghant TMK
03-08-2003 03:58 PM
HACK THS
09-09-2002 12:52 AM
