What should the max. MAF readings (in units of g/s) be on a PES T-28 kit (n-dbw)?
<ul><li><a href="https://forums.audiworld.com/a4/msgs/1910467.phtml">x-post to A4 forum</a></li></ul>
The max reading the ECU can take is 187 g/s
A chipped K03 flows ~160-170g/s with the stock housing, and the 3" MAF housing flows roughly 25% more air, so that translates to 130-140g/s
So, if you're not flowing more than 130-140g/s, then you have a problem, since that's what a chipped K03 flows.
I'd guess it should be hitting somewhere around 170-180g/s at least.
the sensor and ecu are calibrated for a certain performance profile...
part of which is the cross sectioal area of the maf housing. a larger housing with the same sensor will give lower readings.
the maf sensor reads based on the velocity of the air flowing over it.
velocity goes down when cross sectional area of the maf is increased. the maf sensor "thinks" its seeing lower flow, when in reality flow is increased.
Being a ME major that kind of stuff is becoming easy reading for me.
I understand the relationship of area Vs. velocity. I just didnt realize the MAF was able to convert velocity #'s into #'s of g/s.
