From what we know about lower intake temps. Which is a better investment? Water Injectionor a FMIC?
From what I have gathered your intial investment should be an FMIC.
Only because heat soak will kill that little IC that came stock with the car. Then on the other hand to get consistent #'s (by that I mean run after run)to the ground you will need the water mister.
Can't go wrong either way......
Each has it's pros/cons.
A FMIC is more expensive (especially compared to a homemade water injection unit) and has a pressure drop. But there is no fluid to refill or run out, and has less parts to fail.
Water injection has a side benefit of providing a "steam cleaning" effect in the combustion chamber, helping to get rid of carbon deposits.
The main problem is finding a place to mount the water injection pump. Space is at a premium in the A4 engine bay. Plus you have to keep the water reservoir filled. Of course, if you use the stock windshield washer reservoir, then you have plenty reserve.
If you also inject water before the IC, that will help prevent heat soak.
Either way, a chip may be needed to take full advantage of both. I saw timing advance 5-6 degrees with the WI on, flat-lining at 18, it probably could have run even more timing.
I have WI with the stock IC now, but I also have a Spearco IC core waiting to go in. Neither is needed right now, as it's 20 degrees outside, and my car is buried under snow.
Re: From what we know about lower intake temps. Which is a better investment? Water Injectionor a F
I'd go with the FMIC first, as it's a 'permanent' addition, vs having to worry about the water/alcohol level in the reservoir.
I've built a couple of pretty serious turbocharged motors, and have opted for the FMIC first and foremost. Not that water injection wouldn't do the trick - some of my turbo pals are using it with (seemingly) good results.
How about both?
How about both?
Justin517
04-19-2005 06:43 PM
back2black
17
02-04-2004 09:16 PM
LCP
07-29-2003 11:56 AM
CharlieGSanD
Performance and Tuning
34
06-16-2002 09:25 PM
