What will happen if I retain stock chip after I install K04 in my TT 180?
Might run a little lean
The car will still run the stock boost of 11-12 PSI, The ECU will try to compensate fuel as much as it can for the extra CFM. It might run a little lean, you can compensate by using a 4 Bar fuel regulator
Is it possible to recode the ECU to a 225TT?
Not sure, but I know you can recode an A4 to an A6 and the timing map is a little different.
Anyone know for sure or are there other differences like injectors and such?
Mike O.
Mike O.
WOT FREAK (BR)
15
04-29-2005 12:09 AM
ModifiedA4
09-13-2004 09:06 AM
LI-S4
06-17-2002 06:52 PM
Hawaiiannights
08-02-2001 01:15 AM
