Who has a blow-by oil catch can? Pics of your setup? How much oil does it collect / how often?
AudiWorld Expert
I'm thinking of adding one on my S4 as I've felt oil in the Y-Pipe. Shortly I'm going to replace my IC's, so I feel it's probably a good idea to add one now, as to avoid as much oil into the new ICs as possible.
Please tell me all you know about this setup, do's/don'ts, pics, etc.
Thanks
Thanks
Re: Who has a blow-by oil catch can? Pics of your setup? How much oil does it collect / how often?
<center><img src="http://pictureposter.audiworld.com/15899/p8190003.jpg"></center><p>It was a pretty straight forward install. Not sure on the location for the S4. I had to do a bracket for it. Drain it every oil change. I got mine at Jegs.
Mau
Mau
I have the Greddy one... very nice, but....
It's on a A4 1.8t
got a question... on the catch can, it comes w/ clear hoses w/ the white mesh reiforcment. The hoses got very dirty from the oil blow by.. is this normal? It also gets filled about1/3 by each oil change interval. I've seen some other cars w/ teh catch can and clear hoses, and they are still clean. Wierd. Aybody here install one on a DBW 1.8t? i need to pick ur brain.
Re: I have the Greddy one... very nice, but....
I have it on the ATW motor (DBW). My hoses are not clear but I do get oil residue on the outer lip of the filter. 1/3 sounds about right.
Mau
Mau
I'm getting very little blow by now...>>>
<center><img src="http://images2.fotki.com/v20/photos/7/7305/225766/DSC00655-vi.jpg"></center><p>Modified compressor filter on a 1.8.....Only about $30 to install...My oil consumption has dropped to "0" after install...
Here's my setup...
Hey Mark,
Here's my setup that I have.. Its a Canton Racing catch can, you can find them through <a href="http://www.pegasusautoracing.com/pdfs/063.pdf">Pegasus Racing</a> for only $79 bucks..
Here's a pic of my setup..
<img src="http://pictureposter.audiworld.com/744/catchcan2.jpg">
I drilled 6-8 1/8 inch holes...>>>
Around the circumfence of the filter inside the assembly. Around the lower edge, for a little less restrictive flow of air lest the internal filter get oilsoaked.......
Chekm8
9
06-04-2004 11:37 AM
Mark P
10-14-2003 02:45 PM
