Why am I running rich? (stage three 1.8T) Eratic air/fuel ratio.
<center><img src="http://pictureposter.audiworld.com/7507/mtm_stage_3.jpg"></center><p>I recently dyno'd my car and was disappointed with the air/fuel ratio being so inconsistent. I'm hoping some of you might be able to help diagnose the problem in order to create a more consistent air/fuel ratio.
I have MTM stage three. This includes software, 5 bar FPR, Bosch F5DP0R plugs, ported/polished OEM manifold, 3" downpipe, race cat, Milltek exhaust and K04. Keep in mind I did not get everything from MTM, so it's not TRUELY a full MTM system, however everything they spec is what I have on there. I've retained the OEM injectors thus far.
One potential problem is the FMIC. MTM has built their stage three to be used with the OEM side-mount intercooler, and I have a FMIC. This might be a problem, but I don't know.
Also, this chart was run with the older spark plugs in it, not the new ones I referenced above. That might make a difference in the air/fuel ratio, but I certainly cannot feel a difference after putting the new plugs in.
I logged a few minutes of track time with a VAG-COM a couple days ago. That info is in an Excel spreadsheet. If anyone would be willing to look at it I'd be happy to e-mail it to you.
Additionally, I hope to do some more data logging in the next day or two with a wideband sensor and get a much higher sampling rate.
I'm not really sure what my next step is. I really want to make this work with the current software since I don't want to have to buy another chip. But, if I have to move to another tuner's software to get this to work, that's what I'll do.
Any help would be GREATLY appreciated.
Download it its free..
The program is from REVO, it can be found on many websites. I only leanred about it last week.
Be carefull as the warning says. You can F up your car.
Its important to write down your standard settings b4 you start.
