Would installing Schrick Cams be a wothwhile "Mod" ?
No Bozos!
Define "worthwhile"
On my motor worthwhile was, "do we spend $4K on shaving and rolling the head to change the geometry of the combustion chamber, and raising the compression ratio to gain maybe 20 more HP?"
The answer was "yes"
I dont think the cost/hp is going to be all that great.
Schrick cams are not really that cheap and I am not sure how much gain there really is on a stock 1.8t.
BTW if you do go schrick you will also have to buy a adjustable timing gear since the schrick cams come off by 2 deg and will not line up on their own.
when you say adjustable timing gear, can you elaborate?
you mean the sprocket has auto adjusting or you talkin about the belt
i mean...wut is the additional cost when you replace the cam
I am talking about the top sprocket
that connects the timing belt to the cams. The teeth on the schrick cams are off a little and the cam/timing gear had to be added to make sure the cams were lined up correctly. Here is a picture of the motor with the new sprocket installed.
<img src="http://pictureposter.audiworld.com/42349/20vlong.jpg">
Not with a K04....
Cams provide more upper RPM HP, at the expense of low end power.
So with a set of cams, you could flow more air in the upper RPMs, but the K04 can't provide any more air without overspinning, so your not getting any real benefit from them.
You want more ooomph, get a bigger turbo, or NOS
stewarbd
01-04-2009 06:31 PM
