X-Post: How does this MTM Stage 3 data log look to you all....
It seems to be running great and the log looks good to me, but any opinions would be helpful. Cheers! Mike<ul><li><a href="http://home.earthlink.net/~wotmotorsport/sitebuildercontent/sitebuilderfiles/log-01-1aug04-1.xls">http://home.earthlink.net/~wotmotorsport/sitebuildercontent/sitebuilderfiles/log-01-1aug04-1.xls</a</li></ul>
at a glance i see two possible things
your temps seem to be a little high. with my larger setup i never see anything above 100 degree celcius (greddy fmic) and at max load your lambda readings look to be a little lean. other than that your airflow looks good at WOT. you could get away with more timing too 4.5 degrees at WOT seems low to me. maybe i am reading this wrong anyone else care to comment?
those are the water temps, the intake temps were the ones around 38-48 degrees...
thanks about the lambda readings. i'm going to do some more logging on that. Thanks for the reply. Mike
update: i checked the lambdas again and they are all in the 0 and negative on that chart except during idle where they become positive but withing normal limits. If anythink it looks like a slightly rich condition but within normal limits of -6/+6 thanks, mike
bhvrdr
Florida Discussion
14
08-05-2004 07:41 AM
bhvrdr
VAG-COM Discussion
08-01-2004 01:22 PM
SchagenWagen
02-26-2004 09:50 AM
