Xpost -- Manifold questions
I have a PES T-28 kit (1st gen mani)
My turbo took a shi*
Looking to get a gt2871r in place but I"m not sure if it will fit without too much modification. I kinda want to use my test pipe but i also want clearance for that turbo. Is it feasible?
https://forums.audiworld.com/midatlantic/msgs/106569.phtml
Should fit fine, but you might have to make a custom DP
or adaptor if the one off the T28 is different. The only other thing you will have to look at is if the turbo sits in a different spot for the intake tube.
Re: Xpost -- Manifold questions
i did the same thing and found that the part between the old turbo and DP did not line up with the new 2871, the 5 bolts on the back were a diff. bolt patt. also the bolts that hold the turbo to the man. needed nuts on them . also a new intake tube needs to be made. what software are you planning on using? jay
thats the answer i was looking for!! THanks a lot. what a/r is your turbo? It looks like you have a gen 2 mani, i wonder if they're any differences.
Do you have any pics of your setup?
