Yo John Bass. This maybe your kinda thing :)
looks to be sincerely low buck <ul><li><a href="http://www.bgsoflex.com/megasquirt.html">MegaSquirt</a></li></ul>
Checked it out already :)
It's fuel only, and doesn't do sequential.
However, some guys are adapting it as an additional fuel injector controller, which I may look into.
On an unrelated note, do you have a part number for that check valve you have? I couldn't find it on the Jegs website.
ok, cant find it in the catalogs and the unit is unmarked (just made in the USA)
but i'm sure you can email it to jegs cust supp and theyll figure it out
<img src="http://pictureposter.audiworld.com/12079/valves.jpg">
also below that is a typical heater valve, its closed at vac. i'm sure there are bigger ones if you need one and maybe find a serviceable unit that you can adjust to be more sensitive to crankcase vac
This must be it....
<a href="http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=113189&prmenbr=361">http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=113189&prmenbr=361</a>
Used in this kit:
<img src="http://www.moroso.com/catalog/images/25900_part.jpg">
<a href="http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=1783&prmenbr=361">http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=1783&prmenbr=361</a>
I can buy the kit, which comes with two check valves, for less money than two check valves separately....
I wonder if it would be beneficial to put one of these in the downpipe?
I think I'll head down to the local Auto Parts tore and check out the PCV valves to see if there's anything that might work.
Used in this kit:
All the race cars do it, so why can't we?
but I don't know if it will work.
I was looking at using just the check valve from the kit, but I'm curious if it will work in the downpipe, considerring we have a turbo in the way.
