Anyone interested in some Wurth HHS 2000?
AudiWorld Uber User
It's a penetrating lubricant (see link below). I'm gonna order up a case because getting a single can online is stupid expensive. Should work out to $13 a can. You gotta make arrangements to pick it up from my house unless I bring it to a GTG.
And yes, it's THAT good!<ul><li><a href="http://www.paragon-products.com/product_p/wurth_hs2000.htm">http://www.paragon-products.com/product_p/wurth_hs2000.htm</a</li></ul>
AudiWorld Uber User
Hey Ben!!
Still here! Can't believe you're right next door! You should swing by when you're bored!
No pics of the ride (it's an Avant!)...been a little lazy about that. Maybe in the next couple weeks...getting the winter bling blings mounted! Willow Grove has it right now...20K miles on it and it's seeping coolant all over the driveway! *shakes head*
AudiWorld Uber User
Not even nearly the same thing.
As an example, you wouldn't use PB Blaster to lube your rear sway bar. You could use this to lube it...and odds are very good you wouldn't need to touch it again for years.
